Quickgrind Conical Barrel Tool saves you time
Quickgrind’s new series of Eliminator conical barrel end-mills for 5-axis machining incorporate a conical or tapered…
View productOur Aluminium Profile routing cutters are designed for rapid removal of material in extruded aluminium and other soft, non-ferrous materials. Ideal where long tool life and accurate, fine finishes are required, they are available in a wide variety of types designed to suit your applications.
Cutters are available in single or two flute versions, ins tub length, medium and long series and with downward spiral if needed, to hold the material down while cutting thinner sheets. Where a coating is required our unique TX formulation is the favoured choice – its high resistance to abrasion and low co-efficient of friction provides long tool life and excellent surface finish. With a surface hardness of >500Hv and thickness of 0.5-2μm the TX coating helps to maintain the sharp edge of the tool.
Applications & benefits:
Further information available here.
