Hydrafeed MSV80 Barfeeder
The MSV80 is a full servo-driven Barfeed eliminating the need for compressed air. Unrivalled performance and…
View productTurn-Assist Racks
Hydrafeed are the sole UK and Ireland agents for RoboJob’s standard solutions for the loading and unloading of CNC machines
Automation of CNC Machines.
In recent years the machining industry has faced great challenges. It is increasingly difficult to recruit CNC operators; batch sizes have decreased while delivery lead times have shortened.
Hydrafeed, in collaboration with RoboJob, ensures that turning and milling of small and medium-sized batches becomes profitable once again. The Turn-Assist and Mill-Assist robotic systems are integrated solutions which enable the automatic loading and unloading of turning and milling machines. Both systems can be used for a wide range of dimensions (standard ø 5 to 400 mm) and weights (10-700 kg).
The implementation of a RoboJob system will fundamentally reduce the salary costs for machining, and significantly increase the number of spindle hours with substantially less working hours.
CNC Operators can focus on their creative tasks.
The RoboJob system does not require any specific robot knowledge. The user-friendly graphical interface allows all systems to be operated easily and intuitively. CNC operators become more focused on preparation, programming and quality control as the CNC machines are loaded and unloaded automatically.
For more detailed information including technical specifications about RoboJob products please download a brochure alternatively contact us via phone or email and a member of our team will be happy to help.
Specifically for medium sized and large runs
Very flexible and compact automation which was designed specifically for the loading and unloading of medium sized to large(r) batch sizes. On one rack, the raw materials are placed, which the finished pieces are positioned on another rack. These racks can be stacked onto one another.
Ready for the big jobs
This solution can be used for machining work of discs and shafts. We provide the right grippers and the correct software.
A whole range of applications
As a result of its simple concept, this automation can not only be used for large batches but also for smaller and medium-sized quantities as well. We provide you with a universal rack, a chassis on which various grid plates can be placed. For installation, we provide you with at least 1 type of loading tray but you can always order more or even make them yourself. Each loading tray has different dimensions, which are adapted to the dimensions of your workpieces. A label carrier can be provided on a rack so that you can clearly indicate which pieces are in what rack.
Reliable top quality
Thanks to the simple set-up, user-friendly operation and an excellent robot, you’re all set for years to come! The Turn-Assist Racks ensures the capacity of your CNC machine is optimally used. The Turn-Assist Racks can also be transferred to another machine later.
Machining at maximum capacity
This simple solution enables you to get the maximum out of your CNC machine. A robot loads your components directly from a “rack,” a carrier on which the rough and finished parts can be stacked or with which the one rack can be stacked above the other. The robot ensures that your machine continuously remains working further. Smart, and yet simple.
