Quickgrind Conical Barrel Tool saves you time
Quickgrind’s new series of Eliminator conical barrel end-mills for 5-axis machining incorporate a conical or tapered…
View productThe new high performance milling range has an extended reach; unique geometry and Quickgrind’s Xred coating that culminate in a high-performance end mill suitable of machining a vast array of materials. The extended reach of the new solid carbide Delta end mill gives it versatility beyond competitor products whilst its submicron-grain carbide substrate generates unrelenting rigidity. This significantly extends tool life and performance levels. The Delta generates a smooth cutting action that is courtesy of its variable helix flute design and the centre cutting geometry that rapidly evacuates swarf and minimises vibration. The combination of an h6 ground shank, a rigid micro-grain composition and an innovative geometry deliver results with impeccable surface finishes, tool life and material removal rates. These cutters are also Made in UK. Quickgrind Mirage, Mirage Super & Delta brochure
