Have you seen these dedicated tools for mould and die?
Mould and die can be a complicated sector to work within. Fortunately, Hexagon has a suite…
In today’s Technical Corner we explore the benefits of Hexagon Production Software’s RADAN CAD/CAM solutions for sheet metal fabrication. As Liam Smith from Hexagon explains to MTDCNC’s Rowan, RADAN is the total CAD/CAM solution for sheet metal cutting providing applications for punching, profiling, and bending. With the current cost of material it’s essential that you maximize the number of parts you can get from each sheet. RADAN will help you do this using it’s advanced nesting engine to increase yield by approximately 10%. If you have different brands of metal fabrication machines in your machine shop, you can use RADAN as an umbrella software to ensure that you are maximizing your potential across the whole shop. It is essential to keep your machines running all the time, and programming at the machine is now becoming a thing of the past, so RADAN’s offline systems help you keep your machines running longer and increase productivity. If you run a metal fabrication shop you need to talk to Hexagon Production Software now.
