Walter GB Launches Groov·tec GD 5011-P: A New Benchmark in Grooving Systems
Bromsgrove-based Walter GB Ltd has introduced a new cutting-edge platform for parting off, grooving, copy turning,…
As a manufacturer of high-quality end mills and indexable insert milling cutters, Walter Tools offers an extensive selection of milling tools which provide you with an efficient and high-performance solution for any metal milling requirement. For use on CNC-controlled milling and machining centres as well as for conventional milling machines, for large volume as well as for medium and small batch sizes. Neil Mckinnell from Walter Tools explains to MTDCNC’s Joe Reynolds, to provide you with the best possible milling cutter for any machine or machining task in any material Walter supply solid carbide or high-speed steel (HSS) end mills through to special solutions with indexable inserts. With customers wanting to go faster and utilise the full potential of their machines Walter’s new Tiger-tec® Gold, a new generation of cutting tools for milling machines, moves machining to a whole new level. Contact Walter today to find out what they can do for you.
