HAUBEX
The automatic vice change from the tool magazine HAUBEX transforms the tool magazine of your machine tool…
As an interface between the machine table and clamping device, Quick-Point is offered in an extremely wide range of variations. It let’s you adapt to the changing needs of your business by reducuing setup times with a fast, accurate and repeatable system. Offering round, rectangular or square plates, for single or multiple clamping, Quick-Point provides a solution for every machine table and application. It can be used in vertical and horizontal machining centres, on 3- and 5-axis tables and 4th axis rotary or trunnion systems. The attachment of the zero-point plate to the machine table or faceplate is done easily through prefabricated hole patterns for common t-slot distances, bore patterns and bolt circles or individual, customised mounting options.
