MILLTRONICS VM3018 – Vertical Machining Centre
X-axis travel: 762 mm Y-axis travel: 457 mm Z-axis travel: 508 mm Table size: 864 x…
View productMachine now available from stock
The ACTIVE FIVE is a high-speed machining center with fixed portal solution and moving table characterized by a very compact and ergonomic layout. The machine is equipped with a two-axis continuous working head. The design, with the using of the FEM system, has allowed to optimize the finite element calculation making the structures of this model particularly rigid with the total elimination of vibrations during machining.
In addition the low friction and the high acceleration of the axes, allow to achieve particularly brilliant dynamic performance both in finishing and roughing in order to get economic gains in all machining process.
The machine is equipped with automatic tool changer that can be configured and positioned outside the working area. The chips are evacuated by augers that transport them in a scraper type conveyor with side exit. The enclosure with tunnel opening solution leaves the table completely free for loading/ unloading the workpiece and allows easy access to the working area.
Wide possibility of palletizing with different solutions and/or integrations to flexible production systems.
