Darex 3000I Drill Sharpener
The Darex XT-3000 Drill Sharpener is a workhorse sharpener which can be expanded to meet a…
View productMDE is an automatic indexing chuck with hydraulic clamping and indexing. It is not self-centering.
• made in special high resistance hardened and cementing 60HRC steel UNI18NiCrMo5, to maintain a high degree of precision, reliability and quality
• indexing movement (tecnomors patent) simple reliable with only a piston that works in rotation and in clamping position. Indexing precision ± 1’
• guiding system of clamping and of the indexing mechanism. This system uses 2 pre-loaded solid straight roller radially and 1 axial bearing
• seals against contamination by coolant, chips or dust
• constant and long lasting precision
• easy installation to the machine
• the chuck is connected to the rear rotating oil manifold thanks to the nest tube. This tube system is supplied with grinding hardened steel clutch’s
• centrifugal force compensation system for parts susceptible to deformations to obtain an higher productivity performance
• indexing control device
• a good automation system level grows using robot to load and to unload workpieces
• indexing process is possible also in rotation position to allow a fast indexing position passage. The rotation speed has to be not at the maximum power
• indexing takes, with position control, approx. 2-4 seconds per 90°, depending on the size of the chuck
• very simple hydraulic system based on 2 indexing mechanism ports, 2 clamping pistons ports and 1 manifold drain
• the chucking piston is connected to a safety device and keeps the working securely gripped in the jaws even in the event of a complete pressure loss
