GROB G350 (Generation 2) with Automation PLUG & PLAY READY TO GO !
Short availability GROB G350 (Generation 2) with Automation PLUG & PLAY READY TO GO ! HIGH…
The G550 machining center guarantees the best milling technology and extremely stable and precise machining of almost all materials.
Benefit from the process reliability, cost-effectiveness and durability of our unique machine concept and put your trust in the G550 from GROB for reliable production.
The horizontal spindle position enables the greatest possible Z-travel and an optimal chip fall.
GROB unique arrangement of the three linear axes results in a small distance between the guides and the working point (TCP) and a particularly high rigidity of the machine.
The tunnel concept enables the largest possible component to be pivoted and machined within the work area without collision, even with the longest tools.
Three linear and two rotary axes enable 5-sided machining and 5-axis simultaneous interpolation with a swivel range of 230 degrees in the A-axis and 360 degrees in the B-axis.
