They took off the new year with three new product lines.
Vargus manufacture high-end quality inserts – now they’re matching that with high-end quality gauges. With the…
Vargus is pleased to introduce the New ST-CUT, an innovative solution for machining small parts on Swiss-type machines.
In this video, you will find out all you need to know about the new system…
Features and Benefits:
A unique insert replacement system
Quick and easy change of insert inside the machine from both sides of the tool
High repeatability of the cutting edge on all axes
17mm (.669″) maximum parting off diameter, with up to 3mm (.118″) notch width
Excellent rigidity
Insert edge treatment for increased tool life
