Better tool life and reduced inventory with LMT Tools’ high feed milling range!
Are you an engineer who likes high feed milling? LMT Tools have a fantastic range of…
LMT button cutters are a versatile machining solution that can be optimised on newer high-velocity machines as well as older, slow equipment. To be used on newer machining centers, the inserts are now being produced from consistent sub-micron grain-sized carbide substrates. The LMT Tools milling cutters are currently on promotion, so get in touch to learn more.
