Holemaking is no bore with new heads from ITC
Tamworth cutting tool manufacturer Industrial Tooling Corporation (ITC) has further enhanced its world-leading portfolio of bore…
In today’s Technical Corner Ben Morgan from specialist tooling supplier ITC tells us about their BIG KAISER range of products. As Joe Reynolds from MTDCNC discovers all BIG KAISER products are face & taper giving them the ultimate in dual contact performance. As BIG KAISER manufacture the gauge that face & taper spindles are made to ensure that their products are the truest on the market. Their high-power HNC milling chucks are precision ground and balanced for high-speed machining and very rigid for heavy cutting giving security against pullout. BIG KAISER collet chucks have a guaranteed concentricity at the collet nose of less than 0.001 and less than 0.003µ at 4xD and are available for all machine tool spindle systems. Clamping sizes range from 3mm -32mm in various lengths, and collects are available for axial or through coolant systems. The MEGA Synchro Tapping system is perfect for high-performance rigid tapping on CNC machines. It improves thread quality and tool life by reducing thrust loads caused by synchronisation errors by up to 90%. BIG KAISER – big benefits.
