![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/06/28100636/BNGX-Highfeed-640x360.png)
Reduce setup times with the BNGX high feed milling cutter from Dormer Pramet!
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly…
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly versatile! Dormer Pramet’s high feed tool is perfect for job shops that do a bit of everything – steel, stainless, or super alloys.
Tom Skubala of MTDCNC joins Brad Wilson of Dormer Pramet in the MTD Tech Corner to learn more about the advantages of the BNGX, including easy-to-change insert rounds for roughing and finishing, reduced vibration on the machine, and less stress on the tool. If you’re into applications like profiling, face milling, plunge milling, pockets, and helical milling, you’ve got to get your hands on this amazing tool!
