![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/06/28100636/BNGX-Highfeed-640x360.png)
Reduce setup times with the BNGX high feed milling cutter from Dormer Pramet!
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly…
When it comes to turning tips for longer production runs, do you have to sacrifice on performance?
Absolutely not!
MTDCNC’s Tom Skubala is in the Technical Corner with Brad Wilson of Dormer Pramet to learn more about their new T8415 grade – a PVD coated machining tip designed for steel and stainless long production runs and for roughing on super alloys. Providing a thermal barrier between the insert and the workpiece, this tip gives you improved wear resistance and some incredible results!
