5 metres between centres and that’s still small!!
Tom takes a closer look at an impressive SFM machine tool available through Ward HI Tech…
Known for solid and reliable cutting technology, these DAHLIH machines at TIMTOS 2023 are worth seeing! Colin Griffiths of MTDCNC and Richard Pearson of Ward Hi-Tech dive into an excellent newly upgraded model fit for all seasons. The VMC 1050 comes as a standard 3-axis with 4+1 and automation capabilities to handle big depths of cut as well as finer machining. Ward Hi-Tech also supply a range of easy-to-program industrial and collaborative automation solutions to complement DAHLIH machines and keep those spindles running 24/7! If you want to get the best of every machining configuration and great cycle time, check out DAHLIH machines supplied by Ward Hi-Tech in the UK.
[ID4115209454]
