See more and do more with a new operator-friendly HMI.
Starrag’s HMI is all about enhancing the way the system can be used and controlled by…
You might not find another machine in the world that manufactures such complex components this quickly! Starrag’s Lee Scott and MTDCNC’s Paul Jones discuss the Starrag LX 021 – a machine with endless possibilities for turning, milling, and drilling when it comes to complex aerospace engine blades. Designed specifically for 5-axis machining to tight tolerances and a great surface finish, the LX021 with a 30,000 RPM milling spindle and 4,000 RPM main spindle is a compact solution for complete machining in one hit! Check out the full video for a demonstration of all the things that go into making the perfect part.
[ID4718154098]
