This is the largest traveling column series they produce here.
Is there anything you can’t do with the Correa Magna? Take a closer look at the…
The only downtime is a couple of minutes to change one pallet – the spindle will be in action the rest of the time!”
When you combine Correa’s typical FOX machine with an automatic pallet changing system, you get a double column machine that delivers high levels of accuracy and can keep running without interruption. The solution shown in this video is destined for Canada, and after seeing this and many other machines using automation at their factory, it’s clear to see where the future is headed – yes, you guessed it, automation!
