![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/06/28100636/BNGX-Highfeed-640x360.png)
Reduce setup times with the BNGX high feed milling cutter from Dormer Pramet!
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly…
Rowan Easter-Robinson of MTDCNC and Tom Berrill of Dormer Pramet stand in front of a HURCO machine for a demonstration of the 50mm SNGX high feed. Running at 270m/min and 1.7mm per tooth, the SNGX has a fantastic metal removal rate of 550. Hear more from Tom as he shares the added benefits of maximized tool life and reduced dead time with a high feed that gives you the perfect balance of speed and machine cost. If you’re looking for a cheaper option to rough out huge amounts of material especially with lots of batches, the SNGX high feed might be for you!
[ID4535641568]
