Reduce setup times with the BNGX high feed milling cutter from Dormer Pramet!
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly…
Are you tired of switching between two different inserts for intermittent and continuous cutting? Fortunately, you can do all in one with the T9415 steel turning insert from Dormer Pramet! MTDCNC’s Rowan Easter-Robinson is at the Dormer Pramet Productivity Centre in Chesterfield for an incredible machining demo of heavy intermittent cutting on a HURCO machine. Designed specifically for steel, the T9415 is a workhorse of a grade that can go from intermittent to continuous and deliver great performance for steels, stainless, and cast irons. Watch the video to see big intermittent cutting of P20 hard steel at 220 VC with a 2mm depth of cut and 0.2 feed per tooth! If that’s piqued your interest, be sure to check out the Dormer Pramet Face Mill and High Feed demos on MTDCNC.
[ID4535642149]
