Fabrication Made Easy By Axe and Status
Axe and Status supply Durma Press Brakes in the UK. Here Gio finds out more about…
When you think of Axe and Status you think of Pressbrakes, Guillotines and impressive machine tools. But, to add to their arsenal, they now supply Fiber Lasers from Durma.
When you think Durma you immediately think quality, but you may not be aware of their Fiber Laser credentials in the UK. But with over 800 already installed around the world you know that you can rely on a tried and tested machine.
The machines are built using European components including Siemens controls and motors, and IPG lasers so you can be assured of quality.
The machines also afford a lot of flexibility with;
– Lasers from 1kw to 8 kw
– 2 Axis to 5 Axis to enable 3D cutting
– Ability to cut sheet, pipes and tubes
– Envelopes from 1.5m x 3m to what ever size you need
Any more questions, just get in contact with the team at Axe and Status.
