Tebis 4.1 Release 8 – Flexibility Meets Automation
Tebis CAD/CAM/MES is pleased to confirm that Tebis 4.1 Version Release 8 is now available. The…
Tebis parametric template technology stores company’s manufacturing knowledge specific to CAD and CAM. CAD and CAM templates enable faster and more efficient manufacturing, and they also ensure standards and uniform quality. Companies are less dependent on the expertise of individual specialists, and new employees can get up to speed faster and start contributing productively to the company’s success in the shortest possible time.
Faster preparation for manufacturing: Highly automated and flexible preparation of CAM programming with parametric CAD templates
Every data set needs to be prepared for CAM programming in design. Tebis automatically performs many of these necessary individual steps: placing bores for clamping systems, defining tilt axis systems, designing fill surfaces, creating blanks, generating connection points for setups, positioning clamping devices and specifying retract planes. All of these steps work with Tebis parametric CAD templates. The templates can be extended as needed and can be modified to meet customer-specific requirements. Users can still be highly flexible: Changes like selecting a different clamping system can be controlled directly and conveniently. Use parametric CAD templates to fully automatically position clamping devices and generate auxiliary geometries and blanks.
Faster programming with modern NCJob technology in Tebis
Take advantage of the opportunity to automatically apply interactively defined milling areas from previous NCJobs in milling – that’s how you’ll reduce manual intervention in CAM programming and calculate entire NCJob sequences at once. CAM programming is also considerably simplified – you can easily manage combined machining operations in an end-to-end CAM template.
Automated part setup
Tebis automatically and safely positions workpieces and clamping devices on the machine table based on preconfigured connection points. When clamping electrodes, this even works fully automatically and accounts for the holder. This significantly reduces programming work. Individual elements can be rapidly and easily replaced afterwards.
