LISSMAC EBSC Grinding Machine: Precision in Surface Processing!
LISSMAC Corp. introduces the EBSC grinding machine, designed to revolutionize surface processing with precision and efficiency. As…
Impressively productive, the CSD-300II achieves faster robot traverse and turret indexing speeds than its predecessor. For exceptionally quick and accurate turning of a variety of parts, turret index times are as low as .19 seconds, robot cycle times 17.9 seconds and loading times 4.8 seconds.Operation and changeover are easier and more efficient than ever with the CSD-300II.
The horizontal lathe is equipped with an innovative new dual gantry robot and the latest FANUC controls. In addition, the CSD-300II features an improved custom HMI and a single integrated Fanuc control panel that allows for convenient operation and setup of the machine and robot. A clamp/unclamp switch for the robot chuck and the robot’s centralized lubrication system are included as standard. What’s more, the CSD-300II comes ready to quickly connect to IoT, including Fuji’s LAPSYS desktop software. Available as an option, LAPSYS reads scanned laser etchings to trace the origin of a part, including machine and spindle, and enables part traceability, predictive maintenance and remote operation.An optimized bed design, with a grooving width of 14mm, renders this lathe exceptionally rigid. Providing maximum material handling from a compact 2260mm x 1980mm footprint, the CSD- 300II accurately manages heavy parts Ø 200mm x 100mm and 5kg + 5kg. The CSD-300II also features a Fuji-engineered hydraulic clamping loader and 8” – 10” capacity chucks.
