Thompson Friction Welding : Subcontract Linear Friction Welding
What is Linear Friction Welding? Linear friction welding is a solid-state joining process. The technique involves…
tiTend MT-4 Tending System
This system is a flexible modular system which automates the loading and unloading of parts or material for a wide range of machine shop applications. With its intuitive interface this reliable solution can be easily integrated into new and existing production processes. The cell is compact and, easy to install. It can be moved from one machine to another and is easily reconfigured. It’s ability to run autonomously for many hours means that it provides an excellent return on investment.
The flexibility of this system means it can be easily adapted to a variety of production demands such as high mix or low volume. It encompasses a number of key processes to increase productivity and reduce operational costs.
KEY BENEFITS
PRODUCTIVITY
FLEXIBLE
PLUG & PLAY
GENERAL TECHNICAL DATA
Fixed cell size: 1300 X 1700 X 2000mm
Robot model selection: KR10 (6 axis) standard selection,
customisable to suit a full range of CNC machines.
Robot reach: R540 to R1100 without EOAT
Electrical supply: Single phase 50-60Hz 230V 10A
Air supply: 6bar
Control circuit: 24vdc
ADDITIONAL CAPABILTIES
Link for video download: https://designpro.sharepoint.com/:f:/s/Marketing/EkoeLHNFoelFuQEkB0l5YukBb1PKKv421zFvt81ei4XWMA?e=11zCBA
