Incredible world premiere at AMB 2024?
They couldn’t find somebody to get the tolerances they needed – so they used their own…
Kerf Developments will be using MACH 2018 as the launch-pad event for the latest additions to its extensive plasma, waterjet and oxy-fuel cutting product portfolio. In Hall 7 Stand 660, Kerf will be keen to highlight the merits of the new Plasmaster HD (High Definition) system.
This innovative cutting technology will be fitted with the latest Lincoln Electric Flexcut plasma system. Taking plasma cutting to a new level, this next generation technology offers ground breaking levels of performance, price, precision and cut-quality for high definition plasma cutting.
Complementing the Plasmaster HD will be the popular RUR2500p with the highly acclaimed UltraSharp cutting technology. For subcontract profilers, fabricators, structural steel, construction, rail and heavy engineering professionals attending MACH, this stalwart of the Kerf stable provides end-users with a unique cutting solution that combines both speed and precision with consistently high cut quality and the lowest possible cost of manufacture. The engineers from Kerf will be on-hand at MACH to discuss the vast array of available packages, so whether you are processing 1mm thick galvanised plate or cutting through to 70mm thick Hardox, Kerf will have the solution for your needs at MACH 2018.
For manufacturers that need to cut even thicker materials, Kerf will have a heavy duty RUM4500g multi-head oxy-fuel cutting machine on the stand at MACH 2018. This powerhouse cuts material up to 150mm with its standard multiple head configuration. With a UK based team of specialist cutting engineers, Kerf Developments can configure its product line to cut 300mm thick steel with specialised versions of the RUM capable of cutting through mild steel billets up to 750mm thick.
The Rochdale manufacturer will be demonstrating the potential of the market leading RUR and RUM ranges with samples of finished parts that will emphasise the cut quality of holes and external edges that can be processed. Capable of cutting faster than a laser on thicker materials, the RUR2500 will highlight its capabilities and production prospects at the show.
For structural steel fabricators, Kerf will have available a selection of parts cut on the unique PythonX™ machine. This is the leading Robotic Plasma Structural Steel Fabrication System, with over three hundred systems installed worldwide. The PythonX is the ultimate complete manufacturing solution for steel fabricators. It automates processing operations in your factory, increasing productivity, minimising material handling whilst providing the high levels of reliability and cut quality that you would expect from a Lincoln Electric system. PythonX provides a proven manufacturing solution for your business.
The team of application specialists from both Kerf and Lincoln Electric will be on hand to offer advice and guidance on a range of cutting processes including oxy-fuel, plasma, UltraSharp and waterjet. So, if you have a specific cutting requirement, please visit Stand 660 in Hall 7 for the perfect solution.
