Bringing Transparency and Situational Awareness to The Shopfloor – Factory Cockpit at Tasowheel
Tasowheel is a Finnish family-owned contract manufacturer founded in 1979. The company has established itself as…
This new Fastems Modular Flexible Pallet System (FPS) enables lights – out manufacturing and high spindle utilization in high – mix production with 4 – and 5 – axis milling and mill – turn machines, also compact vertical 5 – axis machines. This modular CNC automation solution handles machining pallets and zero – point plates of 300 – 630mm and its unique 360 – degree design ensures a fit for any shop floor – including tight spaces and low – ceiling facilities. FPS can integrate CNCs of over 90 brands and be extended or upgraded if there is a change in production needs.
What sets the new Fastems FPS apart from other pallet handling solutions are its modular 360-degree design, integration capability with over 90 machine brands, and state-of-art productionplanning capabilities. To meet the needs for even the tightest shop floor, FPS’ modular design allowsmachine tools, pallet storage units, and operator loading stations to be placed flexibly on all foursides of the system. With maximum height of only 3.1-3.8 meters, FPS is a perfect fit for low-ceilingfacilities also.To meet the unique production needs of high-mix or low-volume manufacturers, the pallet storagemodules are configurable and use the vertical space efficiently. From four to twelve pallets can beaccommodated every 2 meters depending on the load heights–and the top shelf accommodateshigher loads if needed.In addition, the system ends can be also used for storing pallets. All theshelving units have an in-built coolant collection system to keep the produced parts and surroundingareas clean.The control system of FPS is Fastems’ Manufacturing Management Software (MMS) that is designedspecifically for high-mix manufacturing needs. It is a tool for everyone working in production ormanaging it, giving a real-time view of production activities. Most importantly, it identifies exactlywhat needs to be done next to ensure timely deliveries and maximum spindle utilization. Not onlydoes the system consider the pallets that need to be loaded in the machine tools next, but it alsochecks and ensures that all the other machining resources are there in time–NC programs, cuttingtools, and raw materials. When a rush job is received or anything sudden happens, MMSautomatically adjusts the production plan.“With the 5-axis machining and mill-turn technologies becoming more popular, the automationsystems of today need to be able to handle more demanding objects and reach the machinedifferently. At the same time, manufacturersneed to be able to introduce new workpieces fast andproduce high mix economically. Flexible Pallet System is designed specifically for this need, and it fitsin various production environments”, explains Fastems’ CEO Mikko Nyman. “FPS brings the benefitsof our recently launched Flexible Pallet Tower but for multiple CNCs. The modular system integrateswith a wide variety of milling machines, making the automation investment more accessibleespecially for directly loaded machines without the automatic pallet changer. We are excited toenable the full flexible manufacturing capabilities for this segment and help manufacturers take themost out of their machine tools.” The first systems will be delivered to the customers during the spring of 2024.
More informationabout the modular solution can be found at fastems.com/fps.
