Reduce setup times with the BNGX high feed milling cutter from Dormer Pramet!
Why use a high feed cutter over an end mill? It’s faster, more economical, and highly…
The global tool manufacturer introduces a new addition, the Dormer Shark E894
This high performance HSS-E thread forming tap is suitable for both through and blind holes in a wide range
of workpiece materials. The premium materials used in the taps provide a balanced ratio of toughness,
hardness and heat resistance to the entire tap.
It is available in DIN/ANSI standard and UNC, UNF and Metric thread forms to provide options for world-wide
operations. With a new forming lobe geometry, optimized post-treatment, TiN coating, and oil grooves
providing lubrication up to 3.5xD depth, these taps are the first choice for highly demanding mass production
threading applications.
All the new Dormer products continue the Dormer Pramet promise to be simply reliable.
For more information regarding Dormer Pramet please visit www.dormerpramet.com or contact your local
sales office.
Shark group mix
Shark M12
