Take care of your machine AND the environment with plant-based neat oils.
Why switch from mineral-oil based lubricants to organic ester technology? FUCHS UK give us all the…
Metalworking fluid might be the last thing you have on your list – but it’s absolutely critical for machining operations!
Machining different materials requires different coolant to ensure that perfect surface finish – particularly on expensive operations.
Joe Reynolds of MTDCNC and Paul Tierney of FUCHS Lubricants are here to talk about the uniqueness of FUCHS metalworking fluid when it comes to major gains – like 10% improved tool life. If you’re investing in high-end machines, why not opt for the right lubricant for maximum impact and reduced risk? Find out more about FUCHS Global ECOCOOL range only on MTDCNC!
