5 metres between centres and that’s still small!!
Tom takes a closer look at an impressive SFM machine tool available through Ward HI Tech…
The feature-packed Dah Lih DMX-320 lets you do more than a 3-axis machine and with easier programming! Richard Pearson of Ward Hi-Tech shares more on the benefits of quick setups, greater productivity, and value-add testing capability that ensure the machine is in top accuracy. If you’ve got parts that need to get out the door quickly or you’re machining tight-tolerance aerospace components, the DMX-320, upgraded with the Renishaw AxiSet, could be the perfect solution. Get in touch with Ward Hi-Tech in Sheffield because this machine is available right now!
