Spain Signs Deal for 25 Eurofighter Aircraft in Halcon II Programme
The Spanish government has finalized a contract with the Munich-based NATO Eurofighter and Tornado Management Agency…
Are you running a high volume, multiple shift machine and your sump fills up with sludge and fine debris over time? Can’t run your machine overnight because of fears the sludge build-up will create a machine alarm or broken tool? Matt Kempson from MP Systems shows MTDCNC’s Tony Gunn how this problem can be eliminated. With the use of their maintenance free Cyclonic Debris Removal System (CDR) uninterrupted tank cleaning for high volume machines with filtering chip conveyors is the answer. Keeping your tank clean 24/7 so you can keep ploughing through parts and making money. No more shutting down production to clean out your tank. The CDR does it all on it’s own. Simply watch as the debris builds up in the CDR settling tank and reminds you of what previously was pumped through your machine lines and tooling. Watch this video to see the magic happen.
