Micron repeatability on the YASDA YBM-40i
In this demonstration, we see that the most accurate machine on the planet lives up to its name. the YASDA YBM-40i is truly in a class of its own. The hand-scraped machine made in Japan will repeat again and again. Using a plate, Methods Machine tools created a demonstration part, then rotated the part 90 degrees, 270 degrees, and more They then re-drilled a second plate. You’ll see the guide pin fit the parts in every iteration. If you want to machine with reliable repeatability contact Methods Machine Tools or MTDCNC today.
[ID3381042537]?”L
More from MTDCNC
