![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/09/07215219/prod1-640x360.jpg)
DuPage Machine Products: A Century of Precision Manufacturing and Innovation
Founded in 1923 by Claude Knuepfer, DuPage Machine Products (DMP) has thrived for over a century…
As manufacturers gear up for year-end equipment acquisitions, a critical decision looms: spindle power. In this brief but impactful guide, industry veteran John Miller dissects the importance of spindle power amidst competing attributes, offering actionable insights for a well-informed machinery investment.
Reader Query: As we approach the year’s end, we’re in the process of acquiring new machines. While narrowing down our options, we’ve reached a decision point between two machines, primarily differing in available spindle power. Half of our team emphasizes the importance of spindle power, while the other half prefers focusing on other attributes. How do you assess spindle power when evaluating a machining center?
Miller’s Response: As machine tools continue to evolve, distinguishing between them becomes increasingly challenging. The iron structures supporting these machines appear similar, offering the same tapers, spindle ranges, and controller options. I always advise looking beyond the spreadsheet into intangibles like build quality, service, and ease of automation. Nevertheless, the spindle is the heart of the machine, warranting its own careful consideration.
So, to answer the question: I consider spindle power important, though not nearly as crucial as other spindle attributes like taper, max rpm, and construction (gear versus direct drive, preload type, etc.). The challenge is that these attributes often compete with each other.
A spindle with high rpm may lack low-end torque, and a mega-powerful geared head could be detrimental to finishing operations. Despite this, various aspects of spindle power can be analyzed to ensure a balanced, usable choice that complements your processes.
Determining your shop’s genuine need for high spindle power is typically a common-sense exercise. If your shop deals mainly with one-off prototypes, the need may be minimal. In such cases, where machine time is primarily changeover and setup time, focus on how the spindle complements finishing operations. However, for steady work in one material, higher power may enhance reliability and predictability over time.
Consider your typical part sizes; if you frequently use 4-inch and larger face mills for roughing, more power can smoothen the process. On the other hand, if you work with small parts and use a ¼-inch end mill, the tool may break before the spindle registers a significant increase in needed power.
For a new five-axis machine purchase, consider the toolholders needed for these jobs. In the move toward “done-in-one” setups, longer tool setups may render power unusable due to chatter.
After confirming a genuine need for more power, the next task is to scrutinize the power and torque charts. Pay attention to continuous and duty ratings. The continuous rating is vital for long roughing cycles, while the duty rating may be crucial for a quick facing pass. I’ve seen machines with impressive max power ratings on the spec sheet, only to find out that power is only available within a very narrow rpm band and only for a 2-minute duty rating.
When analyzing power curves, look for usable power in the rpm ranges you typically use. It may be low-end torque for steel and iron, or high-end power for aluminum. For those working with a broad range of materials, a flatter curve is preferable. Confirm this with the type of tools and tool paths you use; smaller tools using dynamic milling strategies may require top-end power.
Often overlooked is whether the machine itself is up to the task of supporting the cuts you’re asking the spindle to make. This necessitates sturdy construction, effective chip management to keep up with the volume, and perhaps thermal management for sustainability. Machines today are often modular, using a common spindle across several models, saving costs but potentially providing less usable power than anticipated.
The conventional wisdom of bigger being better no longer applies, even in hard metals. The tools, tool paths, and more complex parts of today often require a more delicate touch. The key question is simply, “Can we use this power?” You should genuinely need it, the power should complement the materials you cut, and it should be in a machine that supports it. If these criteria are met, buy with confidence. If not, buy with confidence, knowing your other priorities are well covered.
Do you have a machining question? Ask the expert. John Miller leverages more than a decade of industry experience to answer machining questions from MMS readers. Submit your question online at mmsonline.com/MillersEdge.
Original source MMSonline
