![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/06/18162322/Citizen-Machinery-1200-2-640x360.jpg)
Best-ever MACH for Citizen Machinery
Citizen Machinery UK’s stand at MACH was busy right from the opening on the Monday morning…
The decision by sliding-head lathe builders to introduce the ability to remove the guide bush heralded a natural successor to the single-spindle cam auto
Top quality brass lampholder manufacturer S Lilley & Son Ltd (www.s-lilley.co.uk), now in its sixth generation of family ownership, has nearly finished phasing out the 20 or so cam-type, single-spindle bar autos it has used in its Birmingham factory since the 1950s. In their place are to be found 11 modern CNC, twin-spindle, bar-fed lathes up to 65 mm capacity with driven tooling, six of them supplied by Citizen Machinery UK (www.citizenmachinery.co.uk).
Two are Miyano BNA42-MSY fixed-head turning centres of 42 mm capacity installed in 2017 and 2021, while the other four are Cincom sliding-head models (sliders), two for turning, milling and drilling 32 mm bar and two for processing 20 mm stock. Interestingly, to achieve the high speed of production for which outdated cam technology is renowned and couple it with the inherent advantages of CNC technology, namely unattended running and rapid changeover for smaller economical batch sizes, the company operates the sliding-head machines almost exclusively without the guide bush in place.
The reason S Lilley & Son Ltd is able to do this is that most components for the light fittings it makes are shorter than 3.5 times their diameter (3.5D). Normally a ratio of 2.5D is approximately the limit when stock is not supported in a bushing (or by another means such as a tailstock or sub spindle), otherwise the protruding length of bar deflects under pressure from the tool, causing inaccuracy during machining. However, the relatively open tolerances of the lampholder parts produced in Birmingham allows the company to push the limit higher, lowering the cost of manufacturing parts up to 40 percent longer by taking advantage of higher speed production without the guide bush.
Advantages of guide bush-less operation
The rationale for investing in sliding-head lathes and choosing to operate them without the guide bush for most of the time, rather than buying a fixed-head lathe, is due to the sheer speed of production that is possible using the in-line ganged cutters typically found in a sliding-head machine. It allows the linear cross slide to effect very fast tool changes between cuts. Cycles times are considerably shorter and sometimes even halved compared with using a fixed-head turning centre, in which the tool carrier is generally a revolving turret that takes longer to index the next cutter into position.
Due to the bar being clamped by a collet closer to the spindle nose on a slider when it is used without the guide bush, Z-axis stroke is restricted to around one quarter of what is possible when stock slides through a bushing. It is because the whole spindle head rather than just the bar moves in and out of the working area to present the part to platen-mounted tools that can only move in X and Y. However, the shorter Z-axis travel is unimportant in the Birmingham factory, as most components are less than 3.5D.
As the collet grips the bar much nearer the work than in classical sliding-head turning, the more rigid clamping allows deeper cuts to be taken without chatter, resulting in further efficiency gains as well as better surface finishes, even when machining demanding materials.
Guide bush-less operation on a slider brings with it numerous other advantages in addition to all the productivity benefits. Bar of lower dimensional quality and price can be tolerated, as there is no bush for it to seize in. The remnant after the last part has been machined from a bar is around one-third the length left after true sliding-head turning, so there is less material wastage. It can equate to a considerable monetary saving, especially when prices are as high as they are presently, the more so when expensive alloys are being processed. Notable also is that bar of cross section other than round, such as hexagonal or extruded, may be machined if the guide bush is not present.
Indeed, if support is not necessary for the stability of a part during machining, it is better to remove the guide bush as it can actually compromise accuracy. Holding roundness then becomes easier on short components, as the ability to achieve tolerance is dictated by the high quality spindle rather than the bushing. Furthermore it is possible to run at higher rotational speeds to achieve better production rates and surface finishes.
An extra benefit of turning outside diameters in this mode is that multiple passes are feasible, so shallow roughing cuts may be taken to alleviate the chip breaking problems of turning to size in one pass, plus there is potential to prolong tool life. It is not possible to retract components of reduced diameter back into a guide bush if they are longer than the land area of the bush, as the component would not be supported and vibration would occur.
Transition from cams to CNC
S Lilley & Son Ltd’s transition from cam-type to CNC lathes started in 2008, somewhat later than in many manufacturing companies for three reasons. First, as tolerances on its electrical products are not particularly tight, their production is relatively unaffected by the age of a machine tool; second, the fittings are frequently needed in large volumes commensurate with single-spindle cam auto operation; and third, the company was fortunate to employ a highly skilled cam auto setter-operator who retired as recently as 2019. That was when the penultimate cam-controlled machine was sold, the single remaining auto being devoted to a particular long-running job.
The employee’s departure was the trigger for the Lilley family to accelerate the purchase of Cincom sliders. A pair of 20 mm capacity A20-VII models was installed, one in 2019 and another in 2020, as direct, more productive replacements for the former single-spindle cam autos. The A20s also have the advantage of a compact footprint on the shop floor, the area of which is limited in the Birmingham factory.
The new sliders joined an L32 Cincom model installed in 2012 for producing parts up to 32 mm diameter. The machine was swapped in 2017 for a more modern L32-XII. Likewise, this slider is only occasionally used with the guide bush fitted for producing some longer components from bar or tube.
Director Simon Lilley is of the opinion that, even though cam-type lathes can produce more components per hour than their CNC counterparts, the ability to set the latter machines so much more quickly and run them unattended through the night during the week and into a ghost shift on Saturday mornings means that in terms of production output, one Cincom is able to do the work of three of the older single-spindle cam autos.
He described as “a massive advantage” the ability to produce long runs of components on the CNC machines without an operator in attendance, for example 100,000 Lilley hexagonal lock nuts. During the daytime the sliders are ideal for producing smaller quantities of say 500-off, whereas cam-type lathes would need to be set to run a minimum of 10,000-off to be economical and in any case most of this type of work has long since disappeared overseas. Being able to reduce economical batch size so substantially, down to about 100-off, has resulted in substantial savings in inventory and space and the cost of holding large stocks.
Moreover, CNC turning centres seamlessly include what would traditionally be separate second operations. The need for these previously made certain jobs uneconomical on lathes with cam-actuated slideways if a suitable and often expensive attachment could not be sourced.
Chip breaking software raises efficiency
In January 2022 a fourth Cincom arrived, an L32-XIILFV with Citizen’s latest low frequency vibration (LFV) chip breaking technology in the Mitsubishi control. The three existing sliders plus the Miyanos and other fixed-head lathes were approaching full capacity, so the new machine provided flexibility to swap work around on the shop floor and it is also back-up for the remaining, ageing single-spindle cam auto.
Additionally it is the mainstay for manufacturing increasing quantities of a particular type of screw lampholder known as the Edison E14, a heavy brass product available in a range of decorative finishes that is proving extraordinarily popular on world markets.
As with the other sliders on site, the machine is rarely used with the guide bush fitted. So resolute is S Lilley & Son Ltd’s policy in this regard that longer parts up to 5D, which could be regarded as being best produced by sliding-head turning, are instead machined half way in the main spindle and transferred to the sub spindle for the remainder of the turning and milling to be completed. It saves half an hour’s work installing the guide bush and another half an hour removing it, maximising productivity.
More than 95 percent of the Birmingham firm’s turned parts are made from free-machining brass bar, but lately there has been an increase in demand from its customer base for aluminium parts up to 32 mm diameter and for plastic components such as acrylic LED lenses and acetal grommets. About a quarter of the company’s throughput is contract machining of such special components for luminaire manufacturers already buying Lilley brass lampholders and lighting accessories.
Craig Lilley, another director and family member concluded, “Anodising quality 2011 T3 aluminium is not as free-machining as it is made out to be and the 6026 T9 grade we turn is even worse in terms of its tendency to generate stringy swarf. Most plastics are similarly problematic when machined.
“LFV repeatedly oscillates the tool clear of the bar surface for a fraction of a second, fragmenting the swarf into manageable chip sizes. There is no longer a need to stop the machine to clear swarf tangled around the tool and component, so production output is maintained.
“By the simple insertion of G-codes, the function can be programmed to cut in and out during a cycle. It is turned off automatically when it is not needed for chip breaking, so the slight reduction in material removal rate during LFV machining is minimised. It really could not be more flexible.”
