BX300A, BX500A, BX700A
5 Axis Swivel Spindle Head Vertical Machining Centre The BX range by Pinnacle offers the latest…
View productThe Pinnacle LV8 has been designed to provide a cost effective compact machining solution that offers great performance and accuracy. The LV8 is designed to be simple and easy to use with a choice of control system from Fanuc, Siemens or Heidenhain.
The Pinnacle LV8 is designed to perform day after day, and is built on a heavy duty oversized casting and benefits from 30mm wide precision guideways and 32mm precision ball screws. The structure of the machine has been designed to provide minimal overhangs which ensures the accuracy of the machine in the machining cycle. As well as this we have included extra width in the Z axis column which helps with stability and rigidity.
The LV8 is a perfect machine to be integrated into a large scale production line or in a small machine shop.
