Thompson friction welding machines built by KUKA
Thompson friction welding technology provides friction welding solutions in advanced manufacturing processes for a wide variety…
View productMore than 800 Thompson friction welding machines are in production around the globe by world leading OEMs and Tier 1 manufacturers using models specifically designed for joining truck axles, drill pipes, rods, hydraulic cylinders and piston rods. The acclaimed Thompson machine range is designed and manufactured at the same facility at Halesowen in the United Kingdom.
Machine specification:
Machine Tonnage: 60 tonnes
Application suitability: PR;AX;DP;DR;PS;TR;GP
Example:
THOMPSON 3 PR C/S
60T double ended piston rod application machine – configured, and standard options available
Key:
PR Piston rod
AX Axle
DP Drill pipe
DR Drill rod
PS Prop shaft
TR Track roller
