SP 23 Sliding head lathe ‘EX STOCK’
The SP-23 sliding head lathe is an entirely new model capable of 1-inch machining that has…
The ST-38 is the ideal sliding head solution for complex mill-turn parts within the 42mm diameter range. Star’s flagship model is packed with functionality that enables challenging parts to be processed in one set-up.
Three 10 station turrets allow up to 70 tools to be loaded, each tool can be easily removed with Star’s unique clamping mechanism permitting fast set-up changes. The main spindle’s lower turret includes an independent Z3 axis. This axis allows two different features to be machined simultaneously (Z1 + Z3) using Star’s “super-position” control mode.
An independent turret is utilized on the sub-spindle where components up to 150mm can be processed and front ejected. STAR MOTION CONTROL is also included to minimize idle time and thus further reduce cycle time.
Find out more about the ST-38 on Star GB’s website.
This machine is currently located at Star GB’s showroom in Derbyshire. Please contact Star GB to book a demonstration.
