PowerShape
CAD software for complex parts, electrode design, and modeling for manufacture Autodesk PowerShape software (formally know…
View productAutodesk FeatureCAM software automates your workflow from design to NC code. Reduce your programming time and produce consistent, high quality results for CNC milling, turning, multi-tasking and wire applications.
Why FeatureCAM?
Maintain Part Quality
Creating features and operations with automation removes repetitive tasks, eliminating the scope for human error. This increases programming consistency and enables a level of predictability to produce reliable NC code for maintaining part quality.
Comprehensive Machine Support
FeatureCAM supports a comprehensive range of CNC applications including milling, turning and wire applications. The software caters to the programming needs of 3-5-axis mills, multi-tasking turning centers, Swiss-type lathes, wire EDMs and more.
Standardize Practices and Promote Repeatability
FeatureCAM takes the manufacturing knowledge of the programmer to intelligently make decisions and produce results. This encourages manufacturers’ to standardise their best practices, from existing quality standards and promote repeatability between all employees using the same set-up.
Simulation & Safety
Use FeatureCAM collision avoidance tools to create safe, collision-free tool-paths. Visualise your programming with machine tool simulation to validate your work prior to machining. Check for collisions that could result in additional cost or machine downtime.
