SMEC machining centres in stock
Looking for a new machining centre, check the range of SMEC machines out available from Dugard.…
View productX, Y, Z Axis Travel | 800 x 700 X 510 mm |
A ,C Axis Travel | +30°/-110°, 360° |
Spindle Nose to Table (Min-Max) | 150 mm / 660 mm |
Table Size | 610 mm dia / 530 mm sq |
Max Weight On Table | 400 kg |
T-Slot Size | 5 x 18 mm |
Peak Spindle Motor | 18 kW @ 720 rpm |
12k | 237 Nm @ 720 rpm |
Max Tool Diameter | 75 mm |
Max Tool Length | 280 mm |
