![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2024/09/07215219/prod1-640x360.jpg)
DuPage Machine Products: A Century of Precision Manufacturing and Innovation
Founded in 1923 by Claude Knuepfer, DuPage Machine Products (DMP) has thrived for over a century…
Can you guess how many holes are in this part? We’ve got the answer, and it’ll leave you nothing but impressed!
Join MTDCNC’s Tony Gunn and Hwacheon’s Klaus Ludwig for a first look at the new Semi Con machine from Hwacheon. With a fast, reliable, and temperature-controlled spindle, this machine is punching holes 7mm deep and 1mm in diameter in about 6.1 seconds. A special lubrication system allows for constant cooling of the bearings, and that means you can run this spindle 24/7 at maximum RPM! Tune in to find out more about the incredible stability and precision of the Semi Con – a machine that showcases Hwacheon’s position as a leader in the industry.
