BX300A, BX500A, BX700A
5 Axis Swivel Spindle Head Vertical Machining Centre The BX range by Pinnacle offers the latest…
View productBX700 5 Axis Machines by Pinnacle offer the latest and most versatile 5 axis technology in the market. All of the BX range are equipped with the unique A Axis swivel head.
The machine has the option of a fully embedded rotary table which is centrally located for optimal machining capability.
BX700 Swivel Head Milling Machines allow the user to simplify setup and production of complex multi-sided parts due to the enormous amount of flexibility of the rotating spindle head and rotary table working simultaneously together.
Proven in some of the most demanding applications, the BX machine is a revolution in 5 axis machining capability.
Designed by Pinnacle, the BX700 5 Axis Machines incorporate a high rigidity structure and a wide working range, the main structural components of the machine are cast from high quality Meehanite cast iron which is tempered for stress relief and over HB190 hardness to ensure deformation free performance throughout the lifespan of the machine.
You can select from a range of control systems to suit your requirements, as standard the machines are supplied with the latest Heidenhan TNC640 control system, however Siemens and Fanuc control systems are also available on the BX700 and BX500 Rotating Swivel Head Milling Machines.
Features of the BX700 5 Axis Machine:
High precision 5 axis machining centre with rotating spindle head, the range also benefits from a direct drive motor on the rotary table, helping to increase productivity from this market leading machine.
