BX300A, BX500A, BX700A
5 Axis Swivel Spindle Head Vertical Machining Centre The BX range by Pinnacle offers the latest…
View productBX900 5 Axis Rotating Swivel Head Milling Machines by Pinnacle offer the latest and most versatile 5 axis technology in the market.
The BX900 machine can be specified as a BX900T which incorporates a turning function into the machine capability. This allows the user to lock the spindle and use the the rotary table up to speeds of 1200rpm to turn parts. The results are incredible and really show the versatility of this fantastic machine.
The machine has the option of a fully embedded rotary table which is centrally located for optimal machining capability.
BX900 Rotating Swivel Head Milling Machines allow the user to simplify setup and production of complex multi-sided parts due to the enormous amount of flexibility of the rotating spindle head and rotary table working simultaneously together.
Proven in some of the most demanding applications, the BX machine is a revolution in 5 axis machining capability.
Designed by Pinnacle, the BX900 and BX900T Swivel Head Milling Machines incorporate a high rigidity structure and a wide working range, the main structural components of the machine are cast from high quality Meehanite cast iron which is tempered for stress relief and over HB190 hardness to ensure deformation free performance throughout the lifespan of the machine.
You can select from a range of control systems to suit your requirements, as standard the machines are supplied with the latest Heidenhan TNC640 control system, however Siemens and Fanuc control systems are also available on the BX700 and BX500 Rotating Swivel Head Milling Machines
High precision 5 axis machining centre with rotating spindle head, the range also benefits from a direct drive motor on the rotary table, helping to increase productivity from this market leading machine.
