LH500B Horizontal Machining Centre
Features
  • 500 x 500 Table x 2
  • 650 x 560 x 560 mm Travel
  • Index Table 0.001° / (1°)
  • 11/15 KW Spindle Motor
  • Automatic pallet change
  • Chain Type 40-Tool ATC
  • ISO40 Spindle Taper
  • X, Y,Z axis Rapid Feed 30/24/30 M/min
OPTIMAL STRUCTURE DESIGN
EQUIPPED WITH ROTARY TABLE.
  • The major structural parts are manufactured form high quality Meehanite cast iron (GB 300), tempered for stress relief with hardness over 190HB.
  • The structural parts are tempered for stress relief that ensures deformation-free performance year after year.
  • X, Y, Z axis are mounted with roller type linear ways, exhibiting extra high rigidity and loading capacity.
  • Oversized column structure dramatically increases machining stability.
  • Fixed column construction.
ROTARY TABLE
  • HIGH ACCURACY The rotary table employs three-piece teeth plate for high accuracy indexing.
  • HEAVY-CUTTING RESISTANCE The three-piece teeth plate combined with hydraulic locking mechanism allows full teeth engagement. This results in higher rigidity and increased heavy cutting capacity.
40 TOOLS CHAIN TYPE MAGAZINE (STANDARD)
  • The magazine is driven by a precision cam, featuring fast and accurate tool positioning.
  • Tool selection is bi-directional and random for fast tool change.
  • The magazine accepts ISO40 tool shank.
  • The magazine is separately mounted from the cutting area combined with a protection door to protect tools from contamination from chips or coolant.
Pinnacle Machine Tools's Products
