View productDoQuadMill – Improves surface finishing quality around fixtures, clamping systems, and side walls
Face milling cutter with maximum clearance and economy Designed to avoid tool interference in rough and finish face milling operations
Features:
– Face milling cutter with maximum clearance and economy
No interference with side walls, fixtures, and clamping systems
High accuracy
Wiper insert is also available for precision surface finish requirements
– Cutter design optimized for low cutting force and chattering prevention
The insert’s cutting edge features a large rake angle which generates low cutting load, while the large entering angle reduces lifting of the workpiece to ensure stability.
– Ideal for milling workpieces with thin wall/base or when the fixture is weak
Stable cutting performance due to the concave shape cutting edges
Reinforced insert with resistance to fracture
For prices visit www.tungaloyuk.co.uk/wp-content/uploads/2019intro.pdf
Tungaloy UK
The Technology Centre
Wolverhampton Science Park
Glaisher Drive
Wolverhampton
West Midlands
WV10 9RU
United Kingdom
Phone: +44 121 4000 231
Fax: +44 121 270 9694
