New generation of CVD grades T9225 for P25 steel turning with outstanding productivity
Hard outer layer – A new developed hard coating layer, with a high resistance to flank wear.
Thick Al2O3 layer – Provides excellent resistance to high heat and crater wear, especially effective for high-speed machining.
New cemented carbide substrate – Exclusively designed for T9200 series drastically reduces defects in alloys, which greatly improves fracture resistance.
A new surface treatment technology is applied, making T9200 series hard to break
For prices visit www.tungaloyuk.co.uk/wp-content/uploads/2019intro.pdf
Tungaloy UK
The Technology Centre
Wolverhampton Science Park
Glaisher Drive
Wolverhampton
West Midlands
WV10 9RU
United Kingdom
Phone: +44 121 4000 231
Fax: +44 121 270 9694
