Tool for various grooving and parting-off applications
A wide variety of tools reduces machining cost and setup time.
Features:
– Full line-up for internal and external grooving as well as parting-off
– Insert available in PVD and CVD coated, cermet, and carbide grades
– Variety of chipbreakers for diverse applications
Applications:
– Grooving, parting-off, face grooving, turning, and profiling
ISO Application Range:
