Stable parting-off operations due to unique clamping system
Innovative clamping system assures stability in part-off operation
Features:
– 3 types of inserts that are available for different parting-off diameters can be mounted on the same pocket of the toolholder.
Optimized overhang length for stable machining
– Toolholder for sub-spindle
Perfect for parting off a short workpiece in a narrow approach when a sub-spindle is used.
– Unique clamping system for highly rigid clamping
An unused cutting edge is always protected due to the innovative clamping system.
Even if the first cutting edge is chipped, the other unused cutting edge can be used because the insert is clamped in the center.
ISO Application Range:
