AH905 – PVD coated grade for superalloy turning
Speci? ed grade for Superalloy machining New (Al,Ti)N layer has very high oxidation resistance. This provides excellent wear resistance when cutting superalloys.
HMM chipbreaker for superalloy turning. Uniquely designed chipbreaker with 3-dimensional shape
ISO Application Range
