Adjustable tool that reduces the number of required drills
A large-diameter drill has 2 types of cartridges: TDX cartridge for versatile insert and TDS cartridge for economical 6 cutting-edges insert.
Features:
– Highly rigid body and precise insert position
Well-balanced cutting force and stable machining
– Adjustable tool diameter
Available in 5 sizes of drill body
Covering range: ø55 mm (2.165″) – ø80 mm (3.150″)
Shim to adjust drilling diameter
– Available in 2 types of cartridges: TDX and TDS cartridge
Each cartridge option applicable for one body
– Drill body protection
Cartridge design protecting the drill body from damage in machining
ISO Application:
