Indexable drill with 6 cutting-edge insert
The first indexable drill in the world that uses double-sided insert with 6 cutting edges total, reducing tooling cost and delivering high productivity.
Features:
– Economical double-sided insert with 6 cutting edges
Low cutting force equal to single-sided insert
– One type of insert for both central and peripheral pockets
– Enhanced corner of central insert
Cutting edge at obtuse angle preventing premature breakage
– Twisted coolant holes
Improved coolant flow, chip evacuation, and lubrication on cutting edge
ISO Application:
