View productDouble-sided positive insert for semi-finishing to finishing
Multifunctional endmills for semi-fi nish or fi nishing operation with profi le milling or plunging
Features:
– Double sided with positive edge – innovative geometry
The unique twisted peripheral shape provides positive flank clearance for double sided insert.
Positive insert positioning and sharper cutting edge improves cutting action and surface finish.
Highly economical insert with 6 cutting edges.
– High stability
Dove-tail clamping system maintains the rigidity for accurate 3 dimensional machining.
Improves reliability in plunging operations.
Back clearance angle with wall surface avoids chip packing allowing smooth cutting even in machining of square wall.
Optimized geometry of cutting edge offers resistance to chipping in machining of steel and hardened
material.
– High versatility
Modular style endmills with metric and TungMeister thread allows flexibility to be used with various type of shanks or holder in TungHold and TungMeister series.
Combinations of shank lengths and shank material guarantees versatility in machining operations.
ISO Application Range:
