Excellent surface finish and wall accuracy in shoulder milling
Helical cutting edge and large axial rake angle on insert provide smooth cutting in semi-finishing operation.
Features:
– Inserts:
Helical cutting edge for high wall accuracy
Wiper edge for excellent surface finish
Optimized rake angle for sharpness and reliability
4 chipbreaker types for a wide range of applications
Corner radius range up to 3.2 mm (0.126″)
Available in DLC coating and cermet inserts
– Cutter body:
Air holes for improved chip evacuation
Available in coarse- and close-pitch, and long shank cutters
Applications:
– Shoulder milling
– Ramping
– Hole enlarging
– Plunging
– Slotting
– Helical interpolation
ISO Application Range:
